2018 expedition went crazy
zain77
Iraq
Hello, my 2018 Expedition suddenly read the following codes, knowing that I changed the cam phaser last year. It is worth noting that I used the Expedition on a trip and had to use bad fuel because of the lack of improved fuel in that area, and then these faults appeared once. Is there any help in this case? I checked the fuse box and the VVT solenoids, and there was no problem.
Even I don't know where to start!!!!?
Any suggestions pls?
Sorry for my bad language.
Thanks in advance!
Car Scanner ELM OBD2
DTC report
Selected brand: Dodge
VIN: 1FMJU1JT1JEA49554
============1==============
P0010
Raw code: 0010
ECU: Engine control unit
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
============2==============
P0013
Raw code: 0013
Status: Confirmed
============3==============
P0020
Raw code: 0020
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 2 - circuit malfunction
============4==============
P0023
Raw code: 0023
Status: Confirmed
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 2 - circuit malfunction
============5==============
P0135
Raw code: 0135
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction
============6==============
P0141
Raw code: 0141
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit malfunction
============7==============
P0155
Raw code: 0155
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit malfunction
============8==============
P0161
Raw code: 0161
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 2, bank 2, heater control - circuit malfunction
============9==============
P0443
Raw code: 0443
Status: Confirmed
OBDII: Evaporative emission (EVAP) canister purge valve - circuit malfunction
============10==============
P0446
Raw code: 0446
Status: Confirmed
OBDII: Evaporative emission (EVAP) system, vent control - circuit malfunction
============11==============
P2418
Raw code: 2418
Status: Confirmed
OBDII: Evaporative emission (EVAP) switching valve - open circuit
============12==============
P0430
Raw code: 0430
ECU: Engine control unit[Archive (inactive)]
Status: Permanent
OBDII: Catalytic converter system, bank 2 - efficiency below threshold
============13==============
P0420
Raw code: 0420
Status: Permanent
OBDII: Catalytic converter system, bank 1 - efficiency below threshold
============14==============
P0010(00)
Raw code: 001000
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
2020FordRaptor
Nevada
Thanks in advance!
DTC report
P0010
Raw code: 0010
Status: Confirmed
P0013
Raw code: 0013
Status: Confirmed
P0020
Raw code: 0020
Status: Confirmed
P0023
Raw code: 0023
Status: Confirmed
P0135
Raw code: 0135
Status: Confirmed
P0141
Raw code: 0141
Status: Confirmed
P0155
Raw code: 0155
Status: Confirmed
P0161
Raw code: 0161
Status: Confirmed
P0443
Raw code: 0443
Status: Confirmed
P0446
Raw code: 0446
Status: Confirmed
P2418
Raw code: 2418
Status: Confirmed
P0430
Raw code: 0430
Status: Permanent
P0420
Raw code: 0420
Status: Permanent
P0010(00)
Raw code: 001000
Wow that's a lot of codes.
Z
zain77
Iraq
It's really confusing, I don't know what happened to this expedition!!!! It's just thrown codes at once suddenly. Could bad fuel cause such a thing?
Soliyou
OK
Yes, bad gas May cause catalytic converter issues. But I am not sure why all these codes.
Are there any drivability issues?? Is it misfiring?
Z
zain77
Iraq
No driving issues at all, but I can feel some engine hesitation on idle. I just parked it out and didn't take the risk of driving with a whole bunch of these faults till I get some advice to start diagnoses.
Mlarv
Eastern TN
Is the bad fuel still in it? Or did you drive it enough to get a few new tanks? Is the Check Engine Light on? If bad gas is still in it siphon it out and get good fuel in it. Take it slow and easy until the you know th ebad fuel is gone.
Tan Khai Nguyen
