Road noise
memartin
missouri
Noise coming off rear tires on some roads is loud enough talking to passenger is difficult. Chip and seal roads are extremely hard to hear on. 2022 limited. Any ideas?
techdude99
US
The stock tires are not designed with the lower noise levels found in models like the Michelin Defender.
You can try a strategy that includes more quiet tires and sound deadening. Start in the floor panels around the fenders and move toward the center.
Personally I would just go with tires first and see what you think. You can get them through Costco or another store that provides a satisfaction guarantee. In most cases if you don't notice a difference within a few days you can return them with only the mounting and balancing out of pocket.
Hellwig
Try laminated glass for both front windows?
Deadman
Wisconsin
Its pretty normal for many tires. The exhaust also makes a slight drone back there, so it is a challenge to talk if you are on worn rubber. Swap the tires.
