Motorcity muscle
You do not want lube or antiseize on lugs, only clean dry threads. As stated aluminum and steel do not work well together. First tire store tech is going to destroy aluminum lug nuts. If manufacturers thought it would save weight they would use them.Aluminum threads are subject to galling which can seize them to the studs, especially if they're tightened with an impact gun. If you were to use them, use copious amounts of anti-seize and hand tighten them.
