Switched power circuit / fuse # needed for dashcam.
Broncoholic
Space Coast, FL
I used this black/light green wire as a switched power source to control a switched relay for a light bar. You would need to wire in a 10A+ relay for your camera, but at least you get the switched power source you want with no delay after turning the key off. screenshot_20220906_133640_acrobat_for_samsung_def0935494f5afc894a91144ca3b0d2c455901b7.jpg
Password
Is there nothing in the lower right kick panel fuse box that can be used for both switched and constant? I'm having a hard time finding the right fuse to use (constant and switched) and also have the fuse tap oriented in the right direction because there always seems to be a relay or raised piece of plastic in the way.
JJinSFL
South Florida
Just did this on my 03. Fuse#1 is Run/Accessory on it. If there wasn't another option, I was going to just try running it hot and counting on the Blackvue's motion detection to automatically switch to/from parking mode
