BigOleFordFan
I think this falls under the "well, duh" category, hahahaThey would NOT change the fluid without also changing the filter
Hi,Do me a favor if you can, if you get it done, can you check the dimensions of the two pans side by side? specifically the depth, I'm curious if the PPE standard volume pan is the same depth as the OEM plastic pan. I don't have much clearance between the existing pan and my skid plates. last time i checked ppe didn't give those dimensions. I definitely can't fit the extra volume pan.
