How to Remove Door Panel?
MrJohn
I am trying to remove the driver and passenger door panels off an 2003 expedition XLT. I removed the two screws at the bottom, 2 screws under the trim near the door handle, and 1 screw on the rear edge. I lifted up on the power window/lock panel and removed that piece.
The panel moves up and down a little, but there is still something holding it. I didn't want to start pulling on things and break something. Does anybody know what to do next? I want to remove the outside mirror. Thanks.
BikeRider
San Antonio, TX
Did you disconnect the power window and locks? If so, it sounds like you just need to lift up and towards the door with a little bit of oomph. Make it steady, there is a plastic piece that is like a little hook that keeps the door aligned.
M
MrJohn
I read the above description and after removing the screws, which I have done, it says to pry around the door. I tried pulling hard, but the panel wouldn't come off. I went to a car stereo place and they said the door panel lifts up. There feels like an attachment around the ''sail" area. Or are there those Christmas tree plastic inserts like most other cars have?
BikeRider
San Antonio, TX
I just went out and took off the door again to make sure I wasn't dreaming.
-First, I removed 5 screws (3 phillips, 2 Torx).
-Removed the panel for the power windows and door locks, disconnecting the clips.
-Next, I went around the edges and pulled out to remove a few tension clips.
-Last I pushed up pretty hard and the panel came off. Wa-lah, in less than 10 minutes.
BikeRider
San Antonio, TX
Yeah, there is a tension clip there. If you look in the picture at the link, you can see a round hole where it goes in.
M
MrJohn
Wow, just like that.
I've done the first 2 steps.
Where are the tension clips so I know where to pry. I really pulled hard on the corners, but nothing budged. Is there a clip in the sail area? Thanks for all your help.
BikeRider
San Antonio, TX
Yep, clip in the sail area.
Pull the entire door towards you first. There are a couple of them near the bottom and one near the mid left side (it's easier with a clip puller, but it should be okay if you don't have one). If you go back and look at the picture in the link there is a circular hole above where the guy is inserting a tool (page 3). That is where the sail panel clip is. When you finally get them off just push up like a *****! After you get it off, look at the odd shape of the gry clips that go into the metal, that's why it's so hard.
M
MrJohn
Thanks for the detailed description. I should be able to do it now.
The reason I'm removing the door panel is that I'm replacing the section under the outside mirror from an XLT type (no turn signal) to an Eddie Baur type (with turn signal). But to replace the lense assembly, it appears the mirror has to come off to swap lense assemblies. The turn signal wires aren't there also.
BikeRider
San Antonio, TX
That's a perfect link for you then. It's got the wires that you need coded. Just follow the non Pre-Wired steps.
Just out of curiousity, why would you change them? I personally think that the plastic amber cheapens the look of the Eddie Bauer's.
tifanydire
